When I send gcode to machine the z axis goes up to limit switch and stops
jscott6SWZG
jscott6SWZG
Newbie
I had this problem yesterday.
I entered a machine profile and the problem went away....I changed other things
The problem is back today after fusion 360 crashed and continued to crash reloading my file.
I am not sure what clears this problem and am unable to find what cleared it yesterday ...
hyperbolicindustries
You probably have G28 or G53 at the start of your code/operation. Your post processor probably has an option to us either of those or to use [Clearance Plane]. Try using that instead.
jscott6SWZG
Yes on the fourth line from the top have a g28 g91 z0
I have know idea how to select clearance plane in the post processor.
Can you help me make the change?
jscott6SWZG
Found it
select nc program7
edit settings
safe retracts and home positioning
safe retracts  Clearance height
Will try
jscott6SWZG
AAAh seems to be working
Where would I set this up so that it is always set to clearance height rather than editing nc program set ups every time
seth.madore
As far as I recall, Fusion retains the settings of the post processor last selected. However, one could also edit the post processor to default to your preferred settings.
Seth Madore
