Fusion Manufacture
what would be the best strategy to machine these cooling grooves in one pass?
4 REPLIES 4
piotrstrzelczykk
169 Views, 4 Replies
Hello. I have a question about machining a cooling groove with a milling cutter of the same diameter. What machining strategy will allow me to machine this groove (attached in the screenshot) in a single pass and make the cutter enter the material beyond the stock material? Currently, I have managed to achieve a result close to the intended one using the "flat" strategy. Unfortunately, the cutter enters straight into the material in Z axis, and to machine the groove in the narrowest part (2mm), I had to specify its diameter as 1.98mm, causing the cutter to make two passes to finish both sides. Thank you for your help. Regards.
edit: link to the file: https://a360.co/3ZhotnS
4 REPLIES 4
The file you shared doesn't contain any toolpaths, so it's a bit of a guess as to what you've tried.
Are you referring to the small circular grooves, or all of them?
Seth Madore
I'm sorry, it seems I forgot to save the file. Now the file should contain toolpaths.
Okay, but which grooves are you looking at machining with the same-size tool?
Seth Madore
I was thinking about machining all of them with one tool (2mm endmill) and one strategy if possible and groove number one is the narrowest one.
