Fusion Manufacture
What is wrong with 2d Adaptive
3 REPLIES 3
jscott6SWZG
131 Views, 3 Replies
I like the 2d Adaptive tool path it helps my machine cut a lot faster.
Yesterday the toolpath worked fine, but i had too much step over, so i wanted to reduce by optimal load great...tool path generated fine....but I had a little too much air machining so I reduced the size of my closed chain a little bit.
Bam no tool path generated....so I went back to original size and no tool path, deleted tool path original size no tool path.....
please help?
Set 17 2d adaptive 9
Never mind tried again and bingo generated?????
3 REPLIES 3
jscott6SWZG
in reply to: jscott6SWZG
Oh great I finally fluked the lead in positions to where I wanted them (not sure how)...
So then I change tools from 1/2 flat end mill to 1/4 flat end mill....
Guess what lead in positions change.......Geez
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
jscott6SWZG
in reply to: seth.madore
Thank you for responding.
I did a full redesign for a number of different reasons.   This was the first time I really considered designing to make the development of tool paths easier.
The big thing was removing places where a line ends where two surfaces blend together.
Bingo 2 D adaptive works well.
Thanks to your help and many others I finally have a machining work flow that  works great.   Fast, no machine overloading, more accuracy, easy to parametrically change design.
I seem to be a very slow learner.
btw i would post the file but it is back more than a few versions now and will be difficult to locate
again thank you much
