What Is The G53 B0 Line
utekcnc
utekcnc
What is the G53 B0 line all about?  I'm using the Doosan Mill Turn post and keep getting this line and it just alarms out my Doosan Lynx.  Is there anyway to delete it?  My Gibbscam post doesn't have this.
Replies (8)
Boopathi_Sivakumar
@utekcnc
Does this coming on every model or else a particular model or a particular operation?
If it so please attach your model so that we can help you
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
utekcnc
Every operation.  I don't understand it.   I have attached the Fusion file.   Would the Doosan Mill/Turn post also handle the part transfer if I want to combine setups 1 &2
utekcnc
BUMP
LibertyMachine
The G53 B0 line is to send the sub spindle home. If you do not have a sub spindle, then open up the post processor and go to line 1506:
writeBlock(gMotionModal.format(0), gFormat.format(28), gFormat.format(53), barOutput.format(0)); // retract Sub Spindle if applicable
Put a // in front of the writeBlock line. This will turn it into a comment that will not be read by the software
-EDIT-
repeat again at line 3759
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
utekcnc
Thank you.  That makes sense.
LibertyMachine
-deleted-
Seth Madore
utekcnc
It posts the G53B0 either way I have that toggled---yes or no
LibertyMachine
Yeah, I skimmed it quickly and missed it. My bad.
Seth Madore
