Fusion Manufacture
What is causing this immediate "rapid collision with stock"?
4 REPLIES 4
traditional.builds
671 Views, 4 Replies
I have worked this issue out every so often but can not figure out what causes it. I have been reading other forum  posts and I am seeing parts of the solution; thinking it is an issue with my heights. But to attempt to solve this for myself once and for all I made a simple test file to upload here.
Please know that this is a test model. About halfway through the toolpath I have setup there is collision with shaft/holder. I am aware of this, I am only trying to solve the "rapid collision with stock" that happens as soon as the machine touches the piece. Theoretically there is absolutely nothing that is "hitting" or "colliding" with the machine/stock, it is just throwing an error at me. I know there is a reason, I jus have not learned what causes this and how to fix it.
Any and all help would be awesome. I'm sure this has been answered many times before, but I wanted to upload my own example so I can try to see it better.
Thank you in advance,
Mike
4 REPLIES 4
@traditional.builds
Ah, that will be because the stock has not been roughed out first so Fusion when trying to go to the start of the Contour toolpath will crash into the uncut stock, rough out with say a 3D Adaptive and then apart from the Holder collisions all will be well 🙂 🙂 🙂
Thank you for the help. That does the trick, I just added a roughing operation first and that did the trick. Thank you!
rustman1984
in reply to: engineguy
I am also having the collision issue. I am surfacing/ facing the stock before any model milling. I am then using 2D adaptive. I am using stock contours and selecting the bottom face of a pocket. I think that my plunge rates and everything are good. Thoughts on why this happens?
engineguy
in reply to: rustman1984
@rustman1984
Can you upload your Fusion f3d file for investigation, go to:-
File > Export > Select f3d Format > Save to a location on your computer > Then attach the file to yoyr reply using the Attachments facility below your reply.
