What happened to chuck reference slider?
PatrickPowers-CGS
PatrickPowers-CGS
Turning ops. What happened to the slider for chuck reference?
Replies (8)
akash.kamoolkar
@PatrickPowers-CGS Not sure what's going on. Seems to be a problem specific to this file. I can see the chuck plane in every other file I open. I'll create a ticket for this.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
PatrickPowers-CGS
I've had this happen with a few files. This is just the first time I've posted about it.
PatrickPowers-CGS
I'm also getting an invalid reference error when I reference the chuck front on turning op.
akash.kamoolkar
@PatrickPowers-CGS We've determined that these issues only occur when stock mode in the setup is set to "from preceding setup". Can you confirm this?
Akash Kamoolkar
Akash Kamoolkar
PatrickPowers-CGS
You may be right about the slider not being visible only when stock is from preceding setup.  But the issue that I'm having with the chuck front being an invalid reference in a tool path is happening every time.
akash.kamoolkar
@PatrickPowers-CGS can you attach your file here?
Akash Kamoolkar
Akash Kamoolkar
PatrickPowers-CGS
Okay if you edit the setup you'll see that chuck reference is at 4.5 in front of stock back. On the operation labeled ROUGH OD SIDE 1 the back references the chuck front and the offset shows invalid reference.
akash.kamoolkar
@PatrickPowers-CGS I've managed to replicate this issue and i'll make a ticket for it.
Akash Kamoolkar
Akash Kamoolkar
