Fusion Manufacture
Warning: The tool flute isn't long enough.
15 REPLIES 15
Message 1 of 16
486 Views, 15 Replies
I get this warning every time I use 'Trace'. But it won't outreach the flute length..
15 REPLIES 15
Message 2 of 16
CuttingEdgeManufacturing
upload a file or pictures and someone will be able to much more easily help you.
Message 3 of 16
Hereby just a simple file smacked together
Message 4 of 16
seth.madore
This is a known issue, reported as CAM-44706
Seth Madore
Message 5 of 16
in reply to: seth.madore
Where can i find the tickets, or is that not possible?
Message 6 of 16
seth.madore
Fusion bug reports are not visible to those outside of Autodesk, sorry.
Seth Madore
Message 7 of 16
taitsmith7
I assume that this is related.  The attached tool path should give a "Tool Flute isn't long enough" error and it doesn't.
Message 8 of 16
seth.madore
in reply to: taitsmith7
Uhh, it does....
Seth Madore
Message 9 of 16
taitsmith7
Maybe I have some setting incorrect? My simulation does not show any collisions.
Message 10 of 16
seth.madore
Try toggling the full screen button at the top right. Every now and again it may tuck the status bar behind your Windows taskbar..
Seth Madore
Message 11 of 16
taitsmith7
I just cropped out the status bar.  It shows all green as well.  I just opened the archive file that I attached to this post and simulated it to make sure there wasn't a difference between what I sent as well.
Message 12 of 16
seth.madore
Hmm, still can't get it to NOT show collisions. What version of Fusion are you on, it should be 2.0.16985
Seth Madore
Message 13 of 16
taitsmith7
Yes I have :
Fusion 360 2.0.16985 x86_64
Active Plan: Student
Windows 10 Pro 22H2 (19045.3448)
I've found that I get collisions when I change the tool shoulder length to the flute length but not with the shoulder length larger than the cut depth.
Message 14 of 16
engineguy
@taitsmith7 @seth.madore
Hmmm, @seth.madore I am getting exactly the same as @taitsmith7 and I am on the 16985 version, no error unless the shoulder height is the same as the flute height.
Message 15 of 16
seth.madore
in reply to: engineguy
Well this is interesting. I'm asking some folks that know more about what's going on behind the scenes to see if there's something I've done differently.
Seth Madore
Message 16 of 16
seth.madore
So, an update; apparently, there was a Preview Flag that was made accessible in march of '22 to Insiders that contained Simulation improvements, which is why I'm seeing collisions and you are not. We are nearing completion of an improved Collision Checking experience, so you can either wait for that to be release or sign up for the Insider build and have access to what we are currently working on:
Seth Madore
