Warning Sign Creating Chamfer Tool Path
oldtbone55
oldtbone55
I'm in the CAM learning section under the how to create a chamfer section and have followed the instructions to create a chamfer on several edges of the part sample being used but keep getting a yellow warning triangle after I finish creating the chamfer tool path. I've deleted the toolpath several times and started from scratch but I keep getting this warning, "No passes to link". Below is my file if that will help.
Thanks.
LibertyMachine
That's because you missed a very important step. When you made your Setup, you did not define the Body that you were going to be machining. The 2D Chamfer option is somewhat "model aware" and it had nothing to go on, so was only able to do a portion of the work.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
oldtbone55
That's kinda strange since the how to specifically noted not to choose body in the setup. Now that I've done that all of the machining steps have a red warning label next to them. Does this mean I would have to start over and choose body in the setup? I went back to setup and edited it to choose the body but then the red warning labels showed up.
oldtbone55
OK. I went back through each machining process and clicked on OK and the toolpaths were recreated and the warning label disappeared. The chamfer toolpath is now as it should be.
Thanks for your help. Smiley Very Happy
LibertyMachine
In the video@mike.mattera talks about the importance of selecting the body that you are machining, especially if there are multiple parts on screen. He does not say that nothing should be selected. It's a simple misunderstanding..
In all cases, you want to have the active model selected (as well as visible via the light bulb).
Seth Madore
