Fusion Manufacture
Warning: No stock in machining area
2 REPLIES 2
aristoys58
131 Views, 2 Replies
On manufacture, 3d adaptive clearing, I got a warning as follow : empty toolpath and alot of - Warning: No stock in machining area at -0.500000 (some numero). What does it mean  and solution ?
Thanks, Aristo Y. Suratman.
2 REPLIES 2
usually it means that the rest machining is not seeing any left over material or any material to cut. I often find it helpful to put containment sketches on the part in the manufacturing tab, over arears I wish to machine to drive the geometry choices.
seth.madore
in reply to: aristoys58
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
