Fusion Manufacture
Warning: Lead-out is dropped due to linking constraint + Warning: A contour was not machined because the given lead parameters would cause a collision! - in 2D contour toolpath
2 REPLIES 2
hilmerrex
96 Views, 2 Replies
Hi
I am a student at Bergen Art Academy and I help others with cnc projects.
I have to cut out a form in mdf. It's supposed to be a very simple form, and I thought it would be a simple toolpath, but the 2D contour will only cut some of the forms, even though they are totally identical. I attach my fusion file.
I get these warnings:
I have tried to make several set ups and I have used the patten-function to multiply the bodies.
I would be really happy for any inputs 🙂
All the best
Sarah
2 REPLIES 2
seth.madore
in reply to: hilmerrex
As a quick workaround (and a general tip that will make mass-production much more comfortable), I'd recommend programming one single part and then using Pattern > Duplication to apply code to the rest:
I've attached the file for your review 🙂
Seth Madore
hilmerrex
in reply to: seth.madore
Thank you so much! I am really really grateful!
