Warning: Collapses generated below bottom.
Message 1 of 13
I try to generate a swarf toolpath with what I think is a valid selection. But I get the warning: Collapses generated below bottom.
Anyone know what I'm doing wrong? I can't find a thing about this subject.
I added a screenshot for some clarity
Coert
Replies (12)
Message 2 of 13
seth.madore
Could you also share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 13
Hi Seth,
I added the f3d file.
The 'problem' is located in the swarf setup.
Message 4 of 13
I ran in on my machine, no problems there
Message 5 of 13
seth.madore
I'm unsure what the warning is trying to tell us. I've run this by the appropriate team, I'll try to circle back when I have an answer
Seth Madore
Message 6 of 13
paulsra
hi guys, is there a solution to this error yet?
Message 7 of 13
I found out that it occurs when using tool offset (in Z)
Message 8 of 13
zach.allaun
Running into this issue as well in a Trace toolpath. Using the Trace for a chamfer. Setting Sideways Compensation to Left seems to cause it, but I have no idea why.
Message 9 of 13
ed
Same problem here for a Trace chamfer.  Runs fine, just anoying having the warning show up with no explanation what it means or how to fix it.
Message 10 of 13
Collin_Korver
Any update on this error?
Message 11 of 13
Not me! Maybe @seth.madore knows more.
I did mill with this warning tho, with a Swarf toolpath
Message 12 of 13
@seth.madore
Do you know if there is a solution / fix for this? Still getting the warnings!
Message 13 of 13
seth.madore
Could you share a recent file that is showing this error?
Seth Madore
