Want to change Haas POST to turn off flood coolant before retract and tool chang
I am playing with Fusion 360 and I am finding two things that don't make sense to me with the generic Haas post. The first thing that makes no sense is, the flood turns off after fully retracting and prepping for a tool change. This is a problem because it takes time for the coolant to stop pumping out and your tool holders get covered in coolant during the tool change and end up sticking in the spindle and causing a violent pop. This problem could be solved if the Coolant shuts off before retracting giving it enough time to drain the lines and using the forces generated during retract to help drain the line as well. Number 2 thing that does not make sense to me is the spindle waits to completely stop before retracting. It would save time if the spindle began stopping and immediately retracted and then the machine waits for full stop before tool change. This way the spindle is slowing down on the way up to full retract and less time is wasted.
Can anyone set me in the right direction for modifying my post to do this?
