Fusion Manufacture
Using the multi axis, rotary axis
2 REPLIES 2
kimballtZNL6D
182 Views, 2 Replies
When building a tool path for the rotary axis, how do you control/or set the depth of cut?  or make multiple passes.  When I generate a tool path it just goes directly to the surface of my design which does not work.   I need to make a tool path with multiple passes to get down to the final product.
2 REPLIES 2
Hi @kimballtZNL6D
Thanks for posting to the Fusion 360 Forum.
I did check your question and in this case, I would like to suggest the Rotary- parallel is the Finishing toolpath in this toolpath step down is not possible. (Rotary overview).
With the Rotary counter, we can add the depth of cuts as required.
(Rotary -Contour).
The rotary pocket also has the option for depth of cuts. (Rotary Pocket)
THANKS
Pradip Mistry
”Community
CGBenner
in reply to: kimballtZNL6D
@kimballtZNL6D Did the information provided by @pradip.mistry answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
