Fusion Manufacture
Using Disc Cutter and 3D Contour to mill handle undercut
1 REPLY 1
janos79HVN
115 Views, 1 Reply
Hi! I want to use disc cutter for undercut. I find 3D Contour option very usefull for this operation. It generates paths almost perfect. The problem is that the tool does not start cutting on the correct Z height (as you can see on the printscreen below). I tried to find the cause of this, but without success. Any suggestions?
The tool:
3D Contour settings:
1 REPLY 1
janos79HVN
in reply to: janos79HVN
I was inspired after writing the post. Everything works correctly after setting top height - selecting the top plane of the undercut
