Fusion Manufacture
Using a Macro Variable to Decide Part Quantity (HAAS Pre-NGC Post)
0 REPLIES 0
Message 1 of 1
jacobXNNNF
149 Views, 0 Replies
I'm currently trying to build out a post processor in which the part quantity logic is posted with it. Almost all of our jigs allow for 1-4 parts to be made on them and all our CAM files only have the first position setup with operations. If an operator needs to make more parts they input a number in the macro variable #101 and then we manually add in logic to do each strategy and then do a G52 Y offset for however many parts need to be made. Then the program goes to the next strategy and repeats this. Would having this logic post out directly from Fusion 360 be possible without a ton of experience in editing posts? I have made a few custom posts already but those were mostly just fine tuning some settings and adding in some very small custom start codes. Also, below is the logic I currently use for doing this manually. Also, if anyone has a better method of doing this I'm all ears. Just trying to see if I can automate more of my workflow.
(****** POSITION MACRO ******)
(#101 = 0 FOR ALL 4 NECKS)
(#101 = 1 FOR ONLY 1 NECK)
(#101 = 2 FOR 2 NECKS)
(#101 = 3 FOR 3 NECKS)
(*** Fly Cut Positioning ***)
M8
M97 P100
IF [ #101 EQ 1.0 ] GOTO2
G52 Y4.85
M97 P100
IF [ #101 EQ 2.0 ] GOTO2
G52 Y9.7
M97 P100
IF [ #101 EQ 3.0 ] GOTO2
G52 Y14.55
M97 P100
G52 Y0 Z0
IF [ #101 EQ 0.0 ] GOTO2
(*** Inlay Carve Positioning ***)
N2
G52 Y0
M97 P200
IF [ #101 EQ 1.0 ] GOTO3
G52 Y4.85
M97 P200
IF [ #101 EQ 2.0 ] GOTO3
G52 Y9.7
M97 P200
IF [ #101 EQ 3.0 ] GOTO3
G52 Y14.55
M97 P200
G52 Y0 Z0
IF [ #101 EQ 0.0 ] GOTO3
(*** Fretboard Carve Positioning ***)
N3
G52 Y0
M97 P300
IF [ #101 EQ 1.0 ] GOTO1
G52 Y4.85
M97 P300
IF [ #101 EQ 2.0 ] GOTO1
G52 Y9.7
M97 P300
IF [ #101 EQ 3.0 ] GOTO1
G52 Y14.55
M97 P300
G52 Y0 Z0
IF [ #101 EQ 0.0 ] GOTO1
N1
M5
G53 G0 Z0.
X-0.0175
G53 G0 Y0.
G52 Y0
M30
Labels (1)
0 REPLIES 0
