Use Stock from a Previous Operation
jmwallach51
jmwallach51
There was a solution posted to this forum that provided a method to use stock from an operation for a next operation.  However when I tried to use the this method and save stock as an STL file, I get this message window, "Failed to save stock."  Can not load stock either.
Is this an install problem with Fusion 360 or there something I have to do to get this to work?
LibertyMachine
I don't use this often (at all), but I just tested it out and it's working on my end. Care to show a quick Screencast of your workflow, or share the part here?
File > Export > Save to local folder. Return to thread and attach the .f3d file
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
