Fusion Manufacture
use of 2d pocket and 2d adaptive
1 REPLY 1
conjured2018
59 Views, 1 Reply
Hi, I use 2d contour for ability to set tabs.  I go right to 3d pocket for clearing. Please advise as to how 2d pocket and 2d adaptive are used and for what use case. thank you, JR
1 REPLY 1
seth.madore
in reply to: conjured2018
2D Adaptive, for the most part, is used purely for roughing off material at a fixed Z height. It is not model aware and relies on sketches or contour selections off the part to drive the toolpath. It roughs material with a shallow Radial Depth of Cut, but Max flute length for the Axial depth.
2D Pocket is very similar in many respects to Adaptive; not model aware, requires selections etc. This can be used for roughing or finishing, depending on materials, settings, machine, tooling and workholding.
Seth Madore
