Fusion Manufacture
Use bullnose to leave curved fillet at bottom of pocket
3 REPLIES 3
thinicenewday
126 Views, 3 Replies
I would like to leave a curved filet on the bottom contour of a pocket with a 3/8 bullnose end mill. The remainder of the pocket would be milled out by 3/8 end mill. I am using a counter operation followed by a 2d pocket with a flat bottom endmill. The second operation clears the bullnose operation. How can you offset the pocket operation to clear the remainder of the 2d pocket and not remove the fillet?
3 REPLIES 3
Axial stock to leave and radial stock to leave should work for you but can you share your file?
seth.madore
in reply to: thinicenewday
yes, what @Warmingup1953 asks, please share your file here.
To share your file:
File > Export > Save to local folder, return to thread and attach the .f3d/f3z file in your reply
Seth Madore
thinicenewday
in reply to: seth.madore
I was trying those two parameters but was getting an about the z axis height. I figured out now I believe that was because of how shallow the pocket it is. If I set Axial stock to leave to 0 and Radial stock to leave to half of by bullnose end mill diameter, it works as intended.
I've attached an example file with it fixed.
