I apologize if this is not in the correct message board! I am looking to upgrade a couple of computers that do both design and programming. We are swithcing to Fusion 360 and our experience with using Edgecam has been that it will severely slow down the computer and take at times 15 to 20 minutes to generate a tool path. We do not want this to happen anymore and are willing to spend extra up front money to get quick toolpath generation. We are starting to utilize the High Speed Machining method for roughing and this normally creates long tool path and is where we see the problem with slowing down.
Here is a copy paste from a quote we received. Should we up the RAM even further to say 64 GB. Please share your thoughts. Chad
-6th Gen Intel Core i7-6700K (No Overclock, Quad Core 4.0GHz, 4.2Ghz Turbo, 8MB, w/HD Graphics 530)
-Tower 3620 Heatsink(95W)
-Windows 7 Pro English, French, Spanish 64bit (Includes Windows 10 Pro License)
-NVIDIA(R) Quadro(R) K420 2GB (DP,DL-DVI-I) (1 DP to SL-DVI adapter)
-32GB (2X16GB) 2400MHz DDR4 UDIMM Non-ECC
-M.2 512GB PCIe NVMe Class 40 Solid State Drive
-Thermal pad for NVMe SSD
-1TB 2.5 inch SATA (7,200 Rpm) Hard Drive
-C7 M.2 SSD + 2.5 SATA 1-4 HD
