& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I am novice machinist using a Tormach 1100MX with the microarc 4 attachment. As per the attached diagram, I keep my
origin aligned at center axis with the left most tip of the X axis because the microarc is position from the right facing -X. I have programmed a 2.5mm deep cut from the top face before the A axis turns 180 degrees and repeats another 2.5mm cut (to cut the segment free as the stock piece is 5mm thick). What is actually happening is the first 2.5 mm cut is made then the A axis turns 180 degrees and the second cut is at a 5mm depth instead. I am trying to figure out why the second cut goes so deep because as I don't want to destroy or otherwise ruin perfectly good parts. How do I go about making the cuts an equal 2.5mm on each side?
How are you finding Z0?
I run a probe on the top of my workpiece. Previously I tried setting Z0 as the middle of the workpiece to align with the rotary axis but that didn't change my Z heights issue. At the moment, I have my Setup as the center top of the stock piece. When I include the operation that needs A180 turn, it automatically changes the height to a far greater height, Even if doesn't use those heights in fusion. In my attached file. The red box shows the proper Z heights while the Green box is what is spit out after post processing.
Most people would set Z0. at the center of rotation of the rotary axis.
LeoC
For 4th axis work you MUST have z be the center of rotation!
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
