Unable to select object on Manufacture setup for my CNC plasma cut project
sibagatu
sibagatu
Hi, I just purchased the Voronoi Studio Fusion 360 add on, and I am trying to use it to design a simple steel plate with Voronoi pattern to cut out on my CNC Plasma table. I've attached my attempt to design it.
I noticed that after switching to Manufacture, I am unable to finish the Setup step because I can't select any objects on my sketch. For some reason my Voronoi pattern is not selectable there. Could you help to point out what I am doing wrong?
seth.madore
I'm not seeing the issue:
 When you create a Setup, you need to select the objects you wish to cut, and then select them for your profile.
In Plasma cutting, you CAN drive everything off a sketch, but you don't have a sketch that has the pattern needed (unless you need that add-in to see it, which I don't have)
Seth Madore
sibagatu
Hi Seth,
I now able to select the Fractured Body part, but I also have the sketch that shows the outline (frame) of the Voronoi pattern. Basically I need to cut the Gary parts out and leave the blue frame pieces (inlluding the outer rectangular) part intact.
It seems that Fusion 360 allows me to select either the sketch or Fractured bodies items. Can you help to clarify how how I can select both in CNC manufacturing sub menu?
