Fusion Manufacture
Unable to select bottom contour in 2D Contour
7 REPLIES 7
Message 1 of 8
etfrench
196 Views, 7 Replies
Clicking on the bottom contour of this timing belt pulley results in the vertical face being selected.  Selecting multiple of these show just the bottom contours selected, but no toolpath is generated.
Clicking on the bottom face will create a toolpath, however it cuts on both sides of the face which is not the desired outcome.
If the face is projected to a sketch, the toolpath can be created.  This should not be necessary.
ETFrench
7 REPLIES 7
Message 2 of 8
jscott6SWZG
in reply to: etfrench
That’s what I think but it’s usually quicker to make a tool path sketch if it doesn’t work after three tries
Message 3 of 8
matty.fuller
Works perfectly fine for me, one click for a valid contour...
Your file had 5 tiny chains selected, and as you can see they are all Closed Chains which means they probably overlap themselves, which is why no toolpath calculated.
I suspect this is a user issue, not software.
Message 4 of 8
etfrench
in reply to: matty.fuller
One click is not working for me.  Each click is selecting the vertical face.  That toolpath shows what happens when the bottom contour was selected on several adjoining arcs. Attached video shows the bug.
All of the arcs in each tooth were trimmed at each end to the next arc.  There are 90 teeth, so there is a 4 degree angle in each tooth.  There are no overlaps in the tooth form or the circular pattern.  Fusion 360 appears to only be accurate to 6 decimal places.  Here is the output for the endpoints of two left hand arcs in the tooth form from my 2D CAD program:
#1 [Arc], UID: 5, Layer: 0, Color: 15:(LP), LnType: 0:(LP), Width: 0:(LP), #Pts: 3
p1: 0.01274864",1.67737270"
p2: 0.00637435",1.67740256"
p3: 0.00000000",1.67740819"
Center Pt: 0.00170350",-0.00001208", Radius: 1.67742114", Length: 0.01274872"
#2 [Arc], UID: 11, Layer: 0, Color: 15:(LP), LnType: 0:(LP), Width: 0:(LP), #Pts: 3
p1: 0.02268324",1.66839435"
p2: 0.01942696",1.67477677"
p3: 0.01274864",1.67737267"
Center Pt: 0.01268240",1.66731386", Radius: 0.01005903", Length: 0.01465188"
ETFrench
Message 5 of 8
HughesTooling
@etfrench Have you got the New Chaining preview enabled?
It seems to work with one click if I zoom in for the selection but there seems to be some odd leads.
Odd leads also visible in @matty.fuller picture.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
HughesTooling
@etfrench I noticed in your sketch one of the arcs is not constrained. If I add a concentric constraint it makes the arc constrained but then the profile becomes open somewhere!
What I found helps is to delete the unconstrained arc and extend the other.
Now when I select the bottom edge in the manufacture workspace I get a good toolpath without the extra leads. Also note the outer cylindrical surfaces are now merging so points towards a small error in the original sketch.
Mark Hughes
Message 7 of 8
HughesTooling
Looking at the sketch a bit more and it's a lot more complicated than it needs to be and seems like there are some inaccuracies. The 4° angle shows a small error, how did you create this line? If I type 4° in it makes it correct. Did you just sketch or rotate manually then add the angel without actually typing the number? You also have a 0.034 dimension one side and 0.033 the other. Dimensioning seems pretty chaotic.
If you add the small fillets to the model rather than the sketch you can simplify the sketch to something like this. Also take advantage of construction lines to create symmetry. See attached file. Sizes might not be quite right but I did my best to get the sizes off your sketch, note sketch is now fully constrained.
Mark Hughes
Message 8 of 8
etfrench
in reply to: HughesTooling
Adding the concentric constraint and splitting the contour in half, then mirroring it has fixed it.  The concentric constraint also changed the endpoints of the two left hand arcs so they are now identical.  Both endpoints changed to p1: 0.01275891",1.67737260".
ETFrench
