I get this warning when I try and post a NC file.
Is there something I should be doing?
Solved by JonSchaeffer. Go to Solution.
Yes, it could be a right issue.
Can you try to change the security preference to see if it works?
open the Security & Privacy pane of System Preferences, click on the General tab, unlock the pane, and set it to allow applications from anywhere.
Dave
I am new to the Windows version of Fusion.
Which is what I am working on here at work now. (They just finally gave me a laptop to be able to help out with fixture building)
So what should I do with this windows computer to get Brackets installed properly?
It installed for me automatically after I try post processing in CAM for the first time.
The first thing to do is try and post to your desk top or in your My Documents folder. The second is try turning off your antiviruses and see if you can post then.
I can post to my desktop,
I just get an error message everytime I do post.
I would like to use the Brackets editer how to I get that to work?
Well Brackets finally installed on its own when I went in to configure a post. inside of Cam.
It promted me and asked if I wanted to install it. And I clicked yes.
Not much of an answer but this is now resolved.
