Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Unable to install Brackets
9 REPLIES 9
Message 1 of 10
JonSchaeffer
2406 Views, 9 Replies
I get this warning when I try and post a NC file.
Is there something I should be doing?
www.genesisprecisionaz.com
info@genesisprecisionaz.com
Tags (1)
9 REPLIES 9
Message 2 of 10
mfeathers
in reply to: JonSchaeffer
Haven't really tried Fusion much on my Mac but my first thought is: is your Fusion from the app store? Maybe uninstall that and run the installer from Autodesks site.
First impression is some kind of "rights" issue.
Message 3 of 10
Tianq
in reply to: mfeathers
Yes, it could be a right issue.
Can you try to change the security preference to see if it works?
open the Security & Privacy pane of System Preferences, click on the General tab, unlock the pane, and set it to allow applications from anywhere.
Dave
Dave (Qing) Tian
Message 4 of 10
JonSchaeffer
in reply to: Tianq
I am new to the Windows version of Fusion.
Which is what I am working on here at work now. (They just finally gave me a laptop to be able to help out with fixture building)
So what should I do with this windows computer to get Brackets installed properly?
Message 5 of 10
mfeathers
It installed for me automatically after I try post processing in CAM for the first time.
Message 6 of 10
jeff.walters
The first thing to do is try and post to your desk top or in your My Documents folder. The second is try turning off your antiviruses and see if you can post then.
Jeff Walters
Senior Support Engineer, CAM
Message 7 of 10
JonSchaeffer
in reply to: jeff.walters
I can post to my desktop,
I just get an error message everytime I do post.
I would like to use the Brackets editer how to I get that to work?
Message 8 of 10
Tianq
What is your UAC(User Account Control) settings? You may want to try to turn it off if it is not.
http://windows.microsoft.com/en-us/windows/turn-user-account-control-on-off#1TC=windows-7
Dave (Qing) Tian
Message 9 of 10
JonSchaeffer
in reply to: Tianq
Well Brackets finally installed on its own when I went in to configure a post. inside of Cam.
It promted me and asked if I wanted to install it. And I clicked yes.
Not much of an answer but this is now resolved.
Message 10 of 10
All, as a quick addition to this Brackets post. The following refers to Apple Mac version of Fusion360 and Brackets.
I was having trouble with Brackets not working due to a previously installed version conflicting with the Fusion360 integrated version. Both versions broke. To solve the problem closed Fusion360 then I deleted my independent version of Brackets from the Application folder. Then I went to ~/%USER%/Library/Application Support/Brackets/ and deleted all files and subfolders. I then reopened Fusion360 and generated a CAM Post Process file using the 'open in brackets' option. The Application Support/Brackets folder was regenerated and Brackets opened successfully.
