Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Unable to have Z negative while also having X and Y negative
2 REPLIES 2
brwoodfisher
257 Views, 2 Replies
I am currently setting up an older Hendrick CNC router and home (0,0,0) is set to the top right of the table, with the spindle fully retracted. All X and Y coordinates are negative, and Z is also negative.
I have the stock set up so that it is in the home corner. The issue I'm having in Fusion is that I cannot seem to get the Z to be negative when setting the origin with 'Stock box point' to the top right of the stock. Only Y and X are able to be negative and attempting to make Z negative moves the origin completely.
Any suggestions are much appreciated! I'm fairly new to this so I'm still working on understanding how this machine works.
Labels (2)
2 REPLIES 2
You can change it from stock model orientation, BUT
You are confusing Machine coordinates (G53 or G28) with your work offset coordinates (G54).
seth.madore
in reply to: brwoodfisher
When the Z moves down into the material to cut, are you expecting to see Z positive values? What post processor are you using? Does your machine utilize work offsets (G54, 55 etc)?
Seth Madore
