Fusion Manufacture
Unable to Create Custom Threading Cycle
6 REPLIES 6
zachary_smith40
264 Views, 6 Replies
I am working on a piece to turn in my Haas toolroom lathe. I have designed the part and joined components to create a single body. I have tried the threading toolpath but the code shows as a ID stock removal.
I want to create these "fins" which are only .05" thick. Close to .50" deep. I have been attempting to use a grooving tool with a thread path but the geometry screen only allows me to select the smooth portion of the ID and not the actual coil I used to create the thread.
Has anyone else had issues creating custom threaded parts?
Labels (2)
6 REPLIES 6
Is your grooving tool the same width as the space between the fins?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
No the threading tool is not the same width. I want to use the same tool for multiple sizes. The groove tool in my library was designed to cover my largest to smallest.
The original setup was to offset and rerun the program (all in haas VPS). I was hoping the manufacture toolpath generator would allow multiple passes to arrive at the final size.
The reason you can't select the inner face is because it's not actually a diameter, being comprised rather of many surfaces. You'll have to create a cylindrical surface to allow for accurate selection.
That said, it's likely not going to be an easy task to get your simulated toolpath to align with the orientation of your modeled fins 🤔
Seth Madore
I don't believe I fully understand how to arrive at your suggestion. Could you give more detail or timeline video?
Seth Madore
Thanks again. I will attempt to remodel with a less difficult profile
