Fusion Manufacture
UCCNC post rigid tapping M5 stops between holes
1 REPLY 1
woffler1
92 Views, 1 Reply
Iam having a issue with rigid tapping the tapped hole is fine but it keeps stopping between holes and i have to cycle start every hole .
I also get a waring in the nc file feed per rev. is not supported in this post changed to units per minute.
I have attached a NC file and the post file .
  Any help would be greatly appreciated ThanYou
1 REPLY 1
serge.quiblier
in reply to: woffler1
Hello @woffler1
can you indicate what should be the new code according to your tests?
The actual M5, and the following M3 S command are generated on purpose by the post, in the onCyclePoint function.
I believe it was necessary, because it not a usual code in this function.
If you have tested a gcode removing the M5, M3, and have a working example, share it and i can lead you for the post modification.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
