Two holes selected, only one drilled
In this test project I have two slots that I want to mill using 2D Adaptive with predrilled holes.
So I select two faces where the hole should be drilled and all looks fine at first until suddenly the operation drops one of the faces and only one hole is drilled. The result is a stock collision when the mill tries to plunge in the missing hole. #notfunny
Test project: https://a360.co/2T0DJV0
Update: Just in case when you open it the 4.7mm drill operation has only one face selected it was saved with two, like so:
