Fusion Manufacture
Turning
2 REPLIES 2
mikecncf2c72HHH
151 Views, 2 Replies
Turning
Hi I have down loaded Fusion 360 so I try it with my new CNC Lath but there is nothing there only 3D printers.
Is this as normal a con to make pay before I can provie it is right for me?????
2 REPLIES 2
kechao.wu
in reply to: mikecncf2c72HHH
Hi @mikecncf2c72HHH
Do you need turning operations? If you want to create turning operations, you can see a bunch of turning operations under the Turning tab. Also you probably need to create a turning setup before creating turning operations. Here is the document about turning as well: https://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_CAM_turning_html
mikecncf2c72HHH
in reply to: kechao.wu
Thank you for your help
Mike
