Fusion Manufacture
Turning - Tool not roughing OD of part
5 REPLIES 5
markKM8CP
150 Views, 5 Replies
Any way to rough the part OD, and leave .004 for finish pass.
I'm guessing it's because the rough stock on the OD is less than the specified max depth of cut.
Thank you
5 REPLIES 5
seth.madore
in reply to: markKM8CP
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
markKM8CP
in reply to: seth.madore
Here you go, thanks ...
seth.madore
Set your Outer Radius to Stock OD. Result:
Oh, and that collection of NC Programs you have, is that intentional> If you don't want a new NC Program each time you post, you can turn this off:
Seth Madore
markKM8CP
Yes that makes sense, and works perfectly. Thanks
Why does it look like the boring bar is not cleaning up the ID? The drill is .404"dia, and the ID is .440
Thanks again
seth.madore
The same reason your OD Rough was skipping that last section. You've told it there's no material there to machine, so it ignores it.
Set it to this:
Result:
Seth Madore
