Fusion Manufacture
Turning the OD with a boring bar
6 REPLIES 6
bruno3S6JX
164 Views, 6 Replies
Hi everyone,
I was wondering if anyone could help me with an issue in Fusion 360.
First of all, I am new in terms of turning. I recently came across with a part that I am trying to use a boring bar to do an OD profile. However, Fusion does not machine everything on the profile (I already change the clockwise option on the tool) as you can see on the screenshots. I tried to change many things, but without any result.
6 REPLIES 6
seth.madore
in reply to: bruno3S6JX
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
@bruno3S6JX have you tried checking the "machine undercuts" parameter in the passes tab?
Akash Kamoolkar
Software Development Manager
@bruno3S6JX i tried turning on "machine undercuts and it didn't work so i'll make a ticket for this issue.
Akash Kamoolkar
bruno3S6JX
in reply to: seth.madore
HI Seth,
First of all thank you for your time. As you requested I add the fusion file to the post.
Thank one more time.
Hi Akash Kamoolkar,
Thank you so much for your help and time I really appreciate.
bruno3S6JX
Hi everyone,
I got it. After a call with the support, I managed to get it to work properly.
It was a simple think that I tried before, but I don't know why it didn't work.
I just created a sketch of the profile and selected in the toolpath under Model->Model Contour.
However, I didn't got it running in the -X axis like I wanted to so I had to Manual invert the code to the negative side.
