Fusion Manufacture
Turning Template Issue
1 REPLY 1
parilla88
100 Views, 1 Reply
When using a template for Turning Profile Roughing - Geometry > Back > Tool Limit the output is always Contact Point regardless of the setting. i.e if selecting Tool limit > Cutting Edge the output is still Contact Point.
This only happens when using templates. The setting works fine for a new project.
Could someone verify this?
Thank you.
1 REPLY 1
Hi, I checked for you but I didn't encounter any problem. I added the test video I made.
If the answer you are looking for is correct, please accept the solution.
