Turning Profile Not Model Aware
jorsborn
jorsborn
I am having issues with the second op on a lathe part today. The profile operation is blowing right through a shoulder like it's not model aware. Typically when the profile function is misbehaving it is because I forgot to tick the spun profile box but that is not the case here. Any suggestions?
Replies (9)
LibertyMachine
Could you share the file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
jorsborn
F3D attached...
See Setup2. Setup 3 was an attempt at a work around.
LibertyMachine
Set your X axis along this line:
It's certainly being finicky...file attached
Seth Madore
jorsborn
I also noted this issue in your attached file. It's starting the profile at the through hole.Capture.JPG
LibertyMachine
Bugger. So it is. Houston, we have a problem...
Seth Madore
HughesTooling
Pointing the X axis at this corner point seems to work,
Mark
Mark Hughes
Owner, Hughes Tooling
jorsborn
Thank you Mark and Seth. That does seem to work for me.
Jason
akash.kamoolkar
Hey guys,
I managed to replicate this issue. It seems to be a problem with our spun profile algorithm. We're currently trying to replace it with a better algorithm. I will let you know when I have an update.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
LibertyMachine
Great to hear!
Seth Madore
