Turning ID groove retracting to much and rubbing backside of tool on bore.
josh.sapp
josh.sapp
I'm having an issue of the tool retracting to far, beyond stated retract and clearance, in the bore and rubbing the back side. It is probably something simple but I'm missing it. Could you please have a look at the attached file and give suggestions or see if you can recreate the problem. Thank you in advance.
seth.madore
Okay, good news and bad news...
Good news is, you're not missing something simple, this is a bug that's been around for a while.
Bad news?
Well, it's going to be fixed in updated Grooving strategies, which aren't going to be available for our users for some time....
Seth Madore
Spencer.AC
What is the eta on fixing this? I was just about to post about an identical issue.
seth.madore
The new Grooving strategies are a fair bit of time out, I regret to say..
Seth Madore
