Fusion Manufacture
Turning | How do I create a toolpath for a specific face/ faces?
5 REPLIES 5
77_JR
160 Views, 5 Replies
Hi everyone.
im trying to create a roughing and finishing feature that with only machine a grove and leave the other side of the part untouched to be machined after
I’ll make an image to help explain cause I’m terrible at explaining things.
5 REPLIES 5
seth.madore
in reply to: 77_JR
An image would be great, but would you also be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
77_JR
in reply to: seth.madore
i want to machine the grey part as one operation and then the blue faces as a separate operation.
I attached the f3d file 🙂
Many thanks,
programming2C78B
in reply to: 77_JR
in the 2nd tab of your toolpaths, set the Back to the furthest section you want to actually turn.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
in reply to: 77_JR
Yep, two toolpaths, with the Back set to one selection and the Front set to that same selection for the second toolpath:
Seth Madore
77_JR
Great detail man. thanks!
