Turning Heights - From Selection now working correctly
Lonnie.Cady
Lonnie.Cady
When using from selection for the inner height there seems to be some issues.  As you can see in the attached image I have from selection and the inner radius indicator is not showing correctly.Autodesk_Fusion_360.png
HughesTooling
Have you selected the model on the setup, just came up in another thread and I though you might have the same problem
Mark
Mark Hughes
Owner, Hughes Tooling
Lonnie.Cady
@HughesTooling,
Thanks I just double checked and there body is selected in the setup.  So not sure what is up with it.
HughesTooling
Can you attach the file it's a bit difficult to see quite what the part looks like in the picture.
Mark.
Mark Hughes
HughesTooling
It looks like some of the options for ID don't work. If you have a hole through the part and select Model ID it picks that up ok.
But using selection just picks up the model ID and ignores the selection.
Mark
Mark Hughes
Lonnie.Cady
Also grabbing the manipulator and dragging when in from selection mode does not work correclty.  When I drag up it get goes down and dragging down goes up.
Lonnie.Cady
From selection actually does not work for the OD either.
