Turning - finishing toolpath doesn't turn over flats in design
AlanMueller
AlanMueller
When creating a finishing tool path, Fusion is stopping the turning at the end of the conical taper on my part, rather than continuing straight to the back of the part. Any ideas on how to correct this issue?
End of tool path has a radius, which appears to begin going along the straight section of the part, but ends there. When "Make sharp corners" is on, the radius disappears, as I would expect.
AlanMueller
Simple fix: The issue wasn't spun profile, I had my outer diameter set to the OD of the part, which was where the toolpath was stopping. Adding an offset to my outer diameter field fixed the issue.
seth.madore
Glad you got it sorted out!
Seth Madore
