Fusion Manufacture
Turn off rotation C when posting on a lathe.
2 REPLIES 2
StefansB
118 Views, 2 Replies
Work on a Dossan lathe. How can I turn off C rotation by posting on a lathe.
I use the milling option for the slot
I tried several versions but don't come across.
2 REPLIES 2
serge.quiblier
in reply to: StefansB
Hello @StefansB
A lathe has limited travel capabilities in the X minus direction.
Looking at your NC code, I can see coordinates in the range 9 to -16.
The post detected that it cannot fit the toolpath, in the machinable area of the machine.
So, it is switching to machine controlled polar mode.
In this mode XY moves are in fact interpolated using C,X machine moves, keeping the tool in X plus.
It's because of a machine limitation defined in the post, existing in real life.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
StefansB
in reply to: serge.quiblier
Thanks for the reply, here's the solution. Everything is working now
