Fusion Manufacture
Trying to surface mill past the edge of a part.
2 REPLIES 2
louispregler
80 Views, 2 Replies
Trying to ball mill a surface that requires 100% cleanup. The software wants to stop on the exact edge of the surface instead of continuing past a bit. Or it tries to roll over the edge. How do I manage this? Essentially I'm wanting an offset face option like on 2d face. Any Help?
2 REPLIES 2
a.laasW8M6T
in reply to: louispregler
If you are using the flow toolpath you can add a tangential extension
For all the other 3D toolpaths you will have to make a surface and extend it.
See attached example
louispregler
in reply to: a.laasW8M6T
Flow worked perfect in this situation. Much appreciated!
