Announcements
Trying to chamfer around a turning profile
hatch789
hatch789
Hi Guys,
I have searched for 30 minutes in the forums and nothing really addresses my issue so I'll make a new post. My apologies if I am asking something already covered. I'm trying to chamfer around a turning profile. I get close but it doesn't seem to give me an option to chamfer in 3D and if I try 2D it does not work either. What am I missing?
I'd like my Z to be temporarily defined as the regular X axis and I can do that just fine. After this you'd think it would be simple for the part to slowly rotate as the chamfer bit simply moves back and forth completing the chamfer on this profile. See pic below. I feel like I'm missing something obvious and simple to pull this off properly.
a.laasW8M6T
Hi
You can use 2D contour with Wrap.(You need to break the 2d contour into two parts as wrap won't do Cyclic geometry)
You can also use Deburr if you have the Manufacturing Extension
See attached example
