Fusion Manufacture
Trumpf 1030 Postprocessor JavaScript issue
7 REPLIES 7
Message 1 of 8
bow.enoch
242 Views, 7 Replies
Hey,
Can anyone help with the Trumpf postprocessor? I would like to add a variable to get the sheet metal thickness based on stock thickness. (see picture below). I'm new to JavaScript so I need a little help with this.
It's not showing any errors in the script but when I run 'Start Debugging' I get a popup saying 'failed to read properties'
If I save it like this anyway then the post disappears from my post list in Fusion 360.
Note: I think it has something to do with the equation because if I input the value manually it works like expected. But then I did copy/paste the equation from somewhere else(which was part of a writeBlock and it is working fine for that) so I'm not sure what the problem is.
7 REPLIES 7
Message 2 of 8
matty.fuller
in reply to: bow.enoch
In the first line you assign a string to the variable, because it includes parentheses.
Then in the if statement you try to use it for a mathematical comparison to a float. In JavaScript variables have no type, but it won't be able to convert the string to a number because of the parentheses. I would remove those and see how you go.
Message 3 of 8
matty.fuller
To clarify, your first line should read like this:
var StockThickness = (Math.abs(getGlobalParameter("stock-upper-z") - getGlobalParameter("stock-lower-z")))
When you have the parentheses in quotes "(" and use + it concatenates into a string, so the thickness turns into text instead of a numerical value you can do maths with. This worked fine for the writeBlock where you got it from because it was outputting text.
Message 4 of 8
bow.enoch
in reply to: matty.fuller
Hi @matty.fuller
Thanks for the quick reply. I got it to work the way I want now, the parenthesis you mentioned were definitely a problem however I also had to move the variable and if statement into the function block where the PeirceSetSoft variable is being "used". (sorry I don't know what the proper term would be for that 😕 )
thanks, E
Message 5 of 8
matty.fuller
This is a concept known as "scoping" and determines where variables can be declared and accessed within a program:
https://www.w3schools.com/js/js_scope.asp
Message 6 of 8
bow.enoch
Thanks for the information, although I still don't know why that couldn't've been a global variable. I think it has something to do with equation because if I put a number in manually it did work to have it global. (see pic.)
Message 7 of 8
matty.fuller
I did a little experimentation and I think the reason you couldn't use it that way is likely because of when you tried to do so, due to the order of initialization.
I tried to access the parameter in the properties section and couldn't, then tried to use it in onOpen() and couldn't, but it works in onSection(). If you check the dumper post onOpen() is called first and THEN all of the parameters are declared. I think what you might want to do is look at using the onParameter() function to identify when these parameters are declared and use them there, rather than in every section.
Message 8 of 8
bow.enoch
Hey @matty.fuller ,
Do you know of a way to hide some of the Class values based on the selection of Materialtype?
I've been trying with if statement without any luck.
