Fusion Manufacture
TPath simulation: Tool instantly teleports after each retract
1 REPLY 1
FrodoLoggins
80 Views, 1 Reply
Ok so for each instance of this operation inside the pattern the tool does what it needs to, retracts here as expected:
And then BAM it teleports over here to some imaginary starting position I never specified:
Before moving on to the next instance of the toolpath in the pattern.
Instead it should retract, not teleport to the left, move to the next instance, and then move down before the lead-in.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
brekmiller
in reply to: FrodoLoggins
Yes, this is CAM-51125.  We've already fixed the bug and the fix is being validated.  After that, the plan is to push it out to you in a hotfix.  Sorry about the trouble.
This issue affects only simulation.  The post processed NC output is correct.
Brek Miller
Software Engineer
