Fusion Manufacture
Tormach 8L how do i change the X axis on the post?
8 REPLIES 8
Message 1 of 9
leroyNZKRY
376 Views, 8 Replies
Tormach 8L how do i change the X axis on the post? from -x to +x
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: leroyNZKRY
From the beginning section of the post processor:
Turning post for Tormach 8L with a PathPilot control. Use Turret 0 for Positional Turret, Turret 1 for QCTP on Front Post, Turret 2 for QCTP on Rear Post, Turret 3 for Gang Tooling on Front Post, Turret 4 for Gang Tooling on Rear Tool Post.
Seth Madore
Message 3 of 9
leroyNZKRY
every time I change the turret on the tool edit, it errors the post. only turret it works on is 0. I tried the tormach 15L post and it will work, is this an ok option?
Message 4 of 9
seth.madore
What error do you receive, and can you share a sample Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 5 of 9
leroyNZKRY
im using solidworks and hsmworks
this is the error log when i change the turret.
Message 6 of 9
seth.madore
So wait, you're using SW and HSM? Why not use Fusion with integrated CAD/CAM and improved toolpath options? Regardless, I'd still like to see the file. It's possible that this error might be unique to those software platforms and not the post.
Seth Madore
Message 7 of 9
leroyNZKRY
yes, im using solidworks with hsmworks in it. and yes i think after doing a couple tests in fusion360 and creating a post for them it seamed to work correctly. im just more familiar with solidworks and have been using it for 20 yrs.
fusion is just a new adventure. ill keep trying a few work arounds.
Message 8 of 9
seth.madore
You're likely to find that Turning in Fusion is more polished and will quickly outpace what is offered in our other CAM packages.
Seth Madore
Message 9 of 9
ChadRoark
in reply to: seth.madore
Hi Seth,
This is the post that I was referring to in my direct message.
Chad
