Fusion Manufacture
tools disappear from tool library
7 REPLIES 7
Message 1 of 8
tothrt
174 Views, 7 Replies
Hi there!
I use cloud tool library in fusion. I have only one folder there where I create my tools. This is the 3rd time when a lot of tools disappeared from the library. It seems like it sets itself back to a previous state which was actual some month ago. So I dont lose the folder just the recently created tools.
I searched the folder \Users\username\AppData\Local\Autodesk\Autodesk Fusion 360\usernumber\W.login\M\ but there I found just the library which I also see in fusion, without the missing tools.
This starts to become very annoying.
Someone please help me in this!
7 REPLIES 7
Message 2 of 8
programming2C78B
in reply to: tothrt
how many different devices are you using to access your account? I would start with backing up the library locally first on at minimum one machine, we had cloud issues as well until we actually started a backup.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 8
jeff.pek
in reply to: tothrt
In the Fusion side panel, under Assets / CAMTools, do you see the expected library files there?
  Jeff
Message 4 of 8
tothrt
in reply to: programming2C78B
I only use one device to access my account. By backing up the library locally you mean I should save my tool library directly to my computer for example once a week or something?
Message 5 of 8
tothrt
in reply to: jeff.pek
I see a .json tool library file at the assets / CAMTools but it has a really old date, October 27, 2023. Since then I put a lot of tools to my library.
Message 6 of 8
jeff.pek
in reply to: tothrt
Can you see if there are any more recent files on your machine, in %localappdata%\autodesk\autodesk fusion 360\<userid>\W.Login\M\Backup?
Jeff
Message 7 of 8
tothrt
Yes there is a file there from today. I uploaded it to fusion to check, but it still misses a lot of tools.
Message 8 of 8
jeff.pek
in reply to: tothrt
If that file is from today, then it's likely because it just downloaded the (incorrect) file from the Cloud.
I don't know what could explain what you're seeing. It seems possible that the cloud file was just not being updated for some time.
Jeff
