Toolpaths stuck at 0%
FrodoLoggins
Advisor Advisor
FrodoLoggins
Used to generate, won't anymore. Stuck a 0%. Changing to a different ballnose generates in 2 seconds.
Toolpath "Works" was copied but changed to a different ballnose.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
perspicax
I am also having this problem. What can be done to make it generate or get past 0.0%?
seth.madore
@perspicax without seeing your file, it's hard to say. Can you share it here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
perspicax
This continues to happen with multiple different files. The original poster
shared their file so look at that one instead. I can't share my files.
To anybody experiencing the same problem here is the workaround solution:
you have to save and exit the part and re-open it. Fun bonus: fusion will
probably crash when saving and exiting a part that is still "generating" a
toolpath at 0%, so save your other open files as well before trying to exit
the original part. When you re-open the part there will be an error for the
toolpath. Simply regenerate and voila -- it works like it was supposed in
the first place.
