ToolPath - Z axis wrong
Hello
I assembled a simple part that include a box of 150x150x5. Into this box I added a cut of a box of about 9x8x2.5.
When I selected the CAM and setup all data (2D Pocket), the G-Code display a cut of 5.5mm (insted of 2.5mm). Whay?
Thank you
Yuval
HughesTooling
First you have the stock set so there's 1mm on the top off the part so you will end up with 1mm + 2.5mm for the pocket with this setup.
Next in the op you have the bottom height set to Stock Bottom +1mm, you should have this set to Selected Contours and Offset 0mm.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
You might find this link useful, Help CAM tutorials.
Mark
Mark Hughes
