Toolpath issues with a Shapeoko 3XXL and carbide motion
Rhensley32
Rhensley32
We are using Fusion360 and a Shapeoko 3XXL. We are having some weird toolpaths that are kinda offset from what the G-code shows. We are basically cutting a contour of a rectangle but the toolpath does not end where it began. It is offset by about 1/32". It is so weird. The Gcode looks correct but it consistently cuts with the offset. G-cade is attached,
Here is a picture of what we are getting.
Here is a screenshot of the tool path. As you can see the toolpath looks correct,
We are at our wits end. We have new belts, new V-wheels. The machine is mounted to a granite table. Everything seems square.
Anyone have any issues with the firmware or anything like that. Any help would be great!!
Thanks!
RoccoHilton
you probably haven't canceled the tool's departure from the contour
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
