Fusion Manufacture
Toolpath has sharp corners despite "Minimum cutting rad" not set to 0
3 REPLIES 3
FrodoLoggins
85 Views, 3 Replies
Screenshot 2024-01-05 at 10.14.20 AM.pngScreenshot 2024-01-05 at 10.14.45 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
I believe this only applies to the actual contour that it's cutting not the offset/roughing passes.
Please click "Accept Solution" if what I wrote solved your issue!
DarthBane55
in reply to: FrodoLoggins
Use the finishing smoothing deviation thing for the inside offset passes.
This is correct
Seth Madore
