Fusion Manufacture
Toolpath exceeds the maximum ranges
4 REPLIES 4
khang.nguyenADB6H
130 Views, 4 Replies
I was able to generate a tool path with a disc mill however when I used post processor "Doosan Mill/Turn with Fanuc 0i/31i control" to generate NC code it showed error (Toolpath exceeds the maximum ranges for operation "2D Contour3")
Here is what the toolpath looks like
Here is the error log
Information: Configuration: Doosan Mill/Turn with Fanuc 0i/31i control
Information: Vendor: Doosan
Information: Posting intermediate data to 'C:\Users\KHOI\AppData\Local\Fusion 360 CAM\nc\4333.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Sunday, December 3, 2023 2:48:40 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5991.0
Configuration path: C:/Users/KHOI/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/doosan mill-turn fanuc 3.cps
Include paths: C:/Users/KHOI/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Sunday, October 22, 2023 10:48:42 AM
Output path: C:\Users\KHOI\AppData\Local\Fusion 360 CAM\nc\4333.nc
Checksum of intermediate NC data: d93a0e681b21bf8f18d4d376e83345f7
Checksum of configuration: 5123ced806b38553e21a1f574090e235
Legal: Copyright (C) 2012-2023 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.17244
Error: Toolpath exceeds the maximum ranges for operation "2D Contour3".
Error at line: 2639
Error in operation: '2D Contour3'
Failed while processing onSection() for record 483.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Sunday, December 3, 2023 2:48:40 PM
Post processing failed.
Thank you
Labels (1)
4 REPLIES 4
Hi
This is because the toolpath is larger than the Y-axis travel for your machine as set in the post processor.
Most machines have only +-50mm travel, the toolpath is 116mm
What is the Y axis travel for your particular machine, you didn't mention which one you have?
Hi a.laasW8M6T,
I'm currently using PUMA 2600 SYBII from DN Solutions, this is what has been specified inside of its specification for Y-axis travel. Could you please show me how to adjust Y-axis travel inside the post processor. Thank you.
You can adjust it in the post processor, but your toolpath will still exceed the travel limits as the end of the slot is 54.224mm from centerline and you only have 52.5mm travel
That is with making the lead in radius zero too.
The part is just too big to be machined with a tool like that in the Y axis.
You would need to slot it with a tiny 1.5mm endmill using the X axis travel instead
If you do wish to edit the post you can search for lines 933 and 934 and change the values there for the Puma model type
Thanks. I successfully adjusted the post processor and created NC code.
