Fusion Manufacture
Toolpath changes name when double clicking on it
10 REPLIES 10
Message 1 of 11
FrodoLoggins
268 Views, 10 Replies
Ok I finally tracked this down. For years I swore some of my toolpaths would randomly change their name to the name of a different toolpath. I figured out why that is.
If I:
1: Double click (slowly) on a toolpath to copy the text [I don't actually need to copy the text].
2: Double click (quickly) on another toolpath to open it and change it's settings.
Then:
That second toolpath that I opened for editing changes it's name to the name of the toolpath I previously double clicked on to copy it's text.
Here's 2 examples:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
10 REPLIES 10
Message 2 of 11
seth.madore
in reply to: FrodoLoggins
I'll have to try this on a Mac, because I can't get it to reproduce on PC. Poke me in a few days if I've not posted back here!
Seth Madore
Message 3 of 11
FrodoLoggins
in reply to: seth.madore
Hi, were you able to reproduce this?
Message 4 of 11
cshutsy
I can also confirm its been doing this for months for me.
On PC, new file, not touching the keyboard except to type.
Edit: Actually at step two in the original post I don't need to double click for it to happen (and did not in the video). Just the slow double on the first op, then a single click on the second copies the name.
Hmm I happen to have another PC here that I just did a clean install of win10 on. So I installed fusion and was unable to reproduce this issue on there.
Message 5 of 11
ltomuta
I've seen this as well, happening apparently at random as I was clicking around doing the work. Somehow this ends up registered as a Rename comand although it is not clear what the input is.
Also related, Fusion's undo stack captures a lot of rename events even when the description string does not change after F2 is pressed.
Message 6 of 11
cshutsy
I figured out that in my case the trackball software I was using on one PC was somehow exaggerating the issue.
After some playing around I can get it to do it every time on both PCs, one old install and one new, with a regular mouse. The timing of the clicks doesn't seem to matter:
  1. Rename op1 and deselect
  2. Slow double left click on op1
  3. Right click on op2
  4. Left click on op2, which copies the name
I think the trackball I was using was somehow injecting the right click in there somewhere, which is how I was able to duplicate it with just one left click previously.
Message 7 of 11
FrodoLoggins
Hi @seth.madore, were you able to reproduce this?
Message 8 of 11
seth.madore
Negative, either on Mac or PC...
I'll send this up the chain to see if anyone has seen something like this. I can open a ticket, but without a certain method of reproducing, it's going to be a bit of "needle in haystack" process. Note; not doubting your experience with this, the video speaks for itself
Seth Madore
Message 9 of 11
ltomuta
@seth.madore If the dev team could at least reduce the amount of fake Rename events captured by the Undo stuck maybe on a 2nd stage we could focus on how the effective renames are produced when no explicit CTRL+V is pressed.
Message 10 of 11
FrodoLoggins
It looks like this was drastically improved but I still think every month or so it'll happen. If you want to confirm this was fixed I can accept the solution.
Message 11 of 11
seth.madore
Yes, this was fixed in the last update.
Seth Madore
